Old 02-15-2017, 11:25 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The cold/wet starts in first gear is a common issue. You can get rid of it by letting the clutch slip for a few seconds with no throttle input just to warm it up.
The transmission should NEVER grind going into reverse provided the car is not rolling. Reverse is an idler gear that pushed between two other straight cut gears.
Old 02-16-2017, 01:06 PM   #2
tmontague
tmontague's Avatar
well now you got me all confused. It was my understanding that m/t vehicle commonly grind in reverse depending on the position of the wheels relative to the trans. (this is why sometimes you can't shift into reverse and then you let the vehicle roll very slightly and then it's fine)
My '02 Accent did the same thing occasionally and my Yaris always has as well and neither had any trans issues.
Based on what you're saying as this not being normal or healthy, what would/could the cause of this be?
3rd Gear grind hatchbackkid82 General Yaris / Vitz Discussion 92 02-15-2019 05:07 PM
3rd Gear problems fbq262ken DIY / Maintenance / Service 16 02-26-2015 09:18 AM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
Yaris seems to get stuck in 3rd gear when going uphill 47_MasoN_47 General Yaris / Vitz Discussion 16 08-24-2009 12:22 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 06:27 PM
