Old 02-21-2017, 10:53 PM   #1
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
Originally Posted by SirDigby View Post
no. higher compression/cylinder pressure= colder plugs.
I installed a new set of OEM Toyota plugs when I bought my car. plugs don't really have any performance gains until you change something drastically in the engine. if you have a distributor, silver plugs have the least resistance and can give you slightly quicker spark timing, but in a DIS system the computer compensates for the built in resistance of platinum/iridium; if, however, silver is installed it will create a detonation issue because of the lack of resistance.
the advantage comes with a multi-spark system. the only one I have found is okada projects coils, but they are like $900 (but I've heard they work very well)
http://www.okadaprojects.com/usa/products.htm
http://www.ebay.com/itm/NEW-OKADA-PR...xVAIBT&vxp=mtr
T.M. Works also have a lot of ignition products and what I like about them is that upgrades can go in stages. But of course if you are force inducted and want to go for the best then just go Okada!
http://tmworks-web.jp/pages/products_eng.htm
Fluxtasy is offline   Reply With Quote
How to change spark plugs mitsua General Yaris / Vitz Discussion 4 08-14-2015 09:59 AM
Changed Spark Plugs MyzticZ3r0 DIY / Maintenance / Service 4 11-14-2014 12:58 AM
Bigger Spark plug? samuraivince Performance Modifications 6 08-05-2014 04:09 PM
spark plugs walt101786 DIY / Maintenance / Service 0 09-24-2011 05:25 AM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 08:38 PM
