Old 11-14-2014, 12:27 AM   #1
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
Changed Spark Plugs
Hey everyone! I decided to change my spark plugs after 90,000 miles. I've never tried it before so I had a friend to talk me through it. It took about 15 minutes because of a small error on my part. I accidentally smapped one of my spark plugs while trying to remove it . Thankfully, I had some gorilla tape in hand to remove it. Here's a few pictures of my plugs.
[/IMG]http://img.photobucket.com/albums/v444/MyzticZ3r0/20141113_200723.jpg[/IMG]
Besides the faulty handling, it was a really easy job to do. I probably should've done the job sooner, but I'm not worried. A noticed a small.difference with my gas mileage increase .
MyzticZ3r0 is offline   Reply With Quote
Old 11-14-2014, 01:51 AM   #2
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
Did you start threading the plugs in w/ a rubber hose(if it cross threads plug slips in hose) or did you start threading them in w/the spark plug socket. Juist curious.
Toolaholic is offline   Reply With Quote
Old 11-14-2014, 01:54 AM   #3
MyzticZ3r0
I used.a spark plug socket. If you're going to do it yourself, make sure to stabilize the.extension (applying pressure towards the block) as you're unscrewing. Otherwise, you'll end up doing what I did.
Old 11-14-2014, 01:56 AM   #4
Toolaholic
thanks im changing plugs soon in my 2007 yaris. Only 56000 miles but I do not want plugs seizing in aluminum head.
Old 11-14-2014, 01:58 AM   #5
Toolaholic
i plan on using my new SK thin wall deep spark plug socket.
Spark Plugs walt101786 DIY / Maintenance / Service 2 12-12-2011 02:00 PM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 09:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-02-2009 12:50 AM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
