Nice.
You're not too far from me. So I'm assuming you just cut the exhaust off???? Also, I don't think you'll be driving that car on the streets anymore, so why not pull out anything associated with the audio system and do some weight savings? |
![]() Drives: 2007 Yaris Join Date: Oct 2016
I cut the exhaust off right before the can. I also have a stock exhaust for around town. I have a radio and other comforts so that I can drive to the track. I don't like towing and would argue that it's safer driving this car than my tow rig. The bars are well padded and a long way from my head. The B-Spec weight is 2425 lbs with driver. I actually have to add weight at this point. I'm hoping the cold box will be enough, but if not, I can put a spare tire in as ballast.
#3 | |
Didn't realize you still drive the car on the road (didn't think it would be legal due to the roll cage). How much more weight do you have to add to be class legal? Aren't you still adding more to the cage, so that should add some weight. Does the TRD kit you got have the rear sway bar? If not, that should add a few lbs. And good idea about balancing out the weight distribution by the spare tire. I have no knowledge on track/auto-x racing, btw, so I have no clue what parts are legal and not legal in classes. |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#5 | |
#6 | |
I'm not running the rear ARB because it's not part of the kit. |
| budget B Spec rally build slowly coming along | 07dirtyaris | Tracking, Racing, Auto-X Forum | 8 | 08-15-2016 04:21 PM |
| SCCA Houston Region B Spec build :) | FHT_Racing | Tracking, Racing, Auto-X Forum | 126 | 11-11-2014 01:08 PM |
| 1NZ-FE All Motor Build | burned | Performance Modifications | 19 | 10-24-2014 10:56 AM |
| Carbon build up in the throttle body | Sedan | DIY / Maintenance / Service | 18 | 11-15-2013 11:44 PM |
| 12/20/08 Buddy Club USA 5th Anniversary Clearance SALE | DuckinOut | California | 3 | 12-18-2008 12:25 AM |
