Old 03-05-2017, 09:08 AM   #2
tmontague
tmontague's Avatar
Use a crap ton of pb blaster. Grab a large pair of round vice grips. Grab the rubber ball part of the end link. Then take an impact socket onto the nut and blast it off.
Make sure the vice grips are on very tight. You'll tear the boot and need new end links but you'll at least get them on
Sway Bar End Links Help! GiovanniVan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 03-02-2015 11:14 PM
How should the front sway bar be positioned when adjusting coilovers? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-28-2011 11:20 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
front sway bar install birdman DIY / Maintenance / Service 5 10-04-2009 08:41 AM
aftermarket front sway bar end links? jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-08-2009 11:26 PM
