2ZR swap. DO IT! Ask how!
Oh, right. That top allen key. Ouch! I've never had an issue with that one. Was it corroded? The dust cap has done a good job of keeping mine clean.
I suppose you could try grinding a pair of flats on the shaft and putting an adjustable wrench on them. I assume your goal is to preserve the struts? |
| Sway Bar End Links Help! | GiovanniVan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 03-02-2015 11:14 PM |
| How should the front sway bar be positioned when adjusting coilovers? | marlondog | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 03-28-2011 11:20 PM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| front sway bar install | birdman | DIY / Maintenance / Service | 5 | 10-04-2009 08:41 AM |
| aftermarket front sway bar end links? | jookybanana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-08-2009 11:26 PM |
