![]() Drives: Toyota Echo RS 2005 Join Date: Dec 2016
Echo vitz hatchback change oil without jack ?
I'm not equipped
The street is my garage lol It is possible to change the oil and filter without jack on Echo hatch ? I try, and i am able to touch the oil filter and drain plug Seems possible |
It might help to put one side of the car up on a curb.
Lifelong Shade tree Mechanic
Hubcap Enthusiast
Drives: '09 3-door 5-speed Join Date: Jan 2016
I don't have any issues changing my oil without a jack, in the parking lot of my apartment complex. Mine is a '09, but the engine is the same. The drain plug is right there on the side, instead of in the back like most cars. Makes it really easy to reach. The oil filter is easy to grab, too. Heck, it's safer to skip the jack, anyway. No chance of the car falling on you.
Go for it. |
![]() ![]() ![]() ![]() Drives: street-legal go-kart Join Date: Oct 2008
if its stock, you might be able to swing it
mine is on eibach prokits so its a tad low to get a pan under the car
#6 | |
It is necessary to change oil to hot temperature Not burning temp, but hot cold is not good |
#7 | |
Not too hot, (burns!) not too cold (doesnt contain all impurities) JUST RIGHT! (warm)
fast fluid drains hot
I set up everything for all fluid changes after a drive. Then rev engine and drain as quickly as possible. Oil going into the oil pump's relief valve is unfiltered and a tiny piece of junk wedged just right could jam a piston type valve open and kill oil pressure.
The less that settles the best. (obviously must be done avoiding hot fluid on skin) |
| Should i change transmission oil? | Dreamy | General Yaris / Vitz Discussion | 24 | 08-15-2025 09:08 AM |
| Jack Stands, Floor Jack and Oil Filter? | 268i | DIY / Maintenance / Service | 11 | 08-03-2014 04:32 AM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Who here has done oil change without a jack??? | Yawesh | General Yaris / Vitz Discussion | 38 | 01-02-2009 08:06 PM |
