Old 03-07-2017, 12:31 PM   #1
David C
Drives: White '07 3dr LB
I'll check out your links later after work. To answer your questions :
You won't do any damage to the head unit if you plug in more powerful speakers, the head unit self regulate itself. However if you plug in a 10w speaker and drive it to the max of your head unit, you could damage it with high peaks of power. 30w to 50w speakers are great for running them straight from your head unit.
The ohms are the measure of your internal resistance of the speaker coil (impedance). The impedance stays the same in parallel, and defines the current based on the voltage. Stick with the same impedance for the speakers to avoid over or under driving each other.
Envoyé de mon iPhone en utilisant Tapatalk
David C is offline   Reply With Quote
Old 03-07-2017, 06:02 PM   #2
miiser
miiser's Avatar
Drives: yaris 2009
So if I understand correctly the only way to damage my headunit, is by putting really small speakers and put volume to the max? Cause u said about 10w. (U might wanted to write 100?) sorry for my miss understandings.
Have a good work and a good day. I will look forward to hear from you when you finish
miiser is offline   Reply With Quote
2007 hatchback making a weird whirring sound robkay DIY / Maintenance / Service 20 03-19-2016 06:53 PM
Squeaky sound Mikastef DIY / Maintenance / Service 2 03-28-2015 01:56 PM
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 01:53 PM
6 speaker setup and speaker sizes jstantherprsn DIY / Maintenance / Service 0 12-09-2010 11:21 AM
Speaker Rattling kylemhall In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:24 AM
