#24 |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
I'll check out your links later after work. To answer your questions :
You won't do any damage to the head unit if you plug in more powerful speakers, the head unit self regulate itself. However if you plug in a 10w speaker and drive it to the max of your head unit, you could damage it with high peaks of power. 30w to 50w speakers are great for running them straight from your head unit. The ohms are the measure of your internal resistance of the speaker coil (impedance). The impedance stays the same in parallel, and defines the current based on the voltage. Stick with the same impedance for the speakers to avoid over or under driving each other. Envoyé de mon iPhone en utilisant Tapatalk |
| 2007 hatchback making a weird whirring sound | robkay | DIY / Maintenance / Service | 20 | 03-19-2016 06:53 PM |
| Squeaky sound | Mikastef | DIY / Maintenance / Service | 2 | 03-28-2015 01:56 PM |
| Spacer Template for Hatchback Aftermarket Speaker Install | bigsky2 | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 03-12-2014 01:53 PM |
| 6 speaker setup and speaker sizes | jstantherprsn | DIY / Maintenance / Service | 0 | 12-09-2010 11:21 AM |
| Speaker Rattling | kylemhall | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-24-2010 12:24 AM |
