fast fluid drains hot
I set up everything for all fluid changes after a drive. Then rev engine and drain as quickly as possible. Oil going into the oil pump's relief valve is unfiltered and a tiny piece of junk wedged just right could jam a piston type valve open and kill oil pressure.
The less that settles the best. (obviously must be done avoiding hot fluid on skin) |
| Should i change transmission oil? | Dreamy | General Yaris / Vitz Discussion | 24 | 08-15-2025 09:08 AM |
| Jack Stands, Floor Jack and Oil Filter? | 268i | DIY / Maintenance / Service | 11 | 08-03-2014 04:32 AM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Who here has done oil change without a jack??? | Yawesh | General Yaris / Vitz Discussion | 38 | 01-02-2009 08:06 PM |
