#5 | |
![]() Drives: 2012 Red 3 Door Hatch Manual Join Date: Mar 2017
Swapping ECM in America?
Is is possible to swap out my Japanese ECM for an American/Canadian/Puerto Rican one so I it will then have cruise control in the ECM? I bought the car in America and it has a J (for japan) on the first slot of the VIN, I am assuming that the computer was built in japan and doesn't have these features built in. But it makes sense in my head that if I found a manual ECM programmed in America then it would swap over without a hitch. Can you help? |
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| standalone and stock ecu | Radou | Performance Modifications | 0 | 06-16-2013 04:47 PM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
