Old 03-27-2017, 03:58 PM   #1
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Originally Posted by tmontague View Post
The issue that KTS had is that the metal washers are not bored off center like the center sleeve is. Because the washer are held on center by metal tabs on the subframe it becomes impossible to line them up without drilling a larger hole in the washers.
Imo this is a great mod to do but I wouldn't do it unless the oem bushing are starting to wear. Its not a massive difference (although I've yet to push the car hard on corners as i still have my winters on).
My oem bushing were starting to rot and had a crack starting on both of them so it was a good time to upgrade.
I completely understand how it works. I had SuperPro Caster + bushings on my one Ep3 and the Whiteline +.5 Caster bushings on the other Ep3 I owned. I just stating they're not available anymore, so you'd have to use another set with similar size, or make your own like Perrin did for the WRX/STI back in 2004-2005.
MugenRep is offline   Reply With Quote
FS NorCal: Yaris/Prius C Partout: KW V3 / Whiteline / Greddy Ti-C / Etc B2FiNiTY Items for Sale by private party 25 04-25-2014 01:47 AM
Whiteline Polyurethane Bushing Review Monstro Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-15-2013 11:24 AM
alternator bushing JAMMED ! Siffleu DIY / Maintenance / Service 12 10-22-2010 10:12 AM
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 04:23 AM
NEW NST SS Shifter Bushing (AE86) NonStopTuning NonStopTuning 3 10-01-2007 03:12 PM
