![]() ![]() Drives: 2007 3dr hb 5sp Join Date: May 2012
2012 SE 5 Speed grinding gears
Have 60k miles. Clutch is good, bled for the heck of it to see if it would help any. It didn't. Only grinds when shifting from 3rd-4th at 4k rpms and up. Feels sloppy and clicks under 4k when going in to gear. . Will not grind from a 5-4 downshift. I even changed from Mobil 1 to Redline and no difference. My last Yaris had 185k with original clutch, and never an issue. What gives? Anyone else had these types of issues in their low mileage Yaris?
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
You might barely squeak by the power train warranty guidelines so if so I'd just make toyota fix it.
-Karl the Uber/Lyft Driver |
id take it to toyota pronto to see if you can get it warrantied
otherwise, buy some amsoil or redline gear fluid (severe gear or mt90 respectively) to see if it helps.
#4 | |
![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
Warranty. The syncros on 3rd to 4th are probably shot for whatever reason. Unless you drive real hard all the time, it failed prematurely. Sent from my iPhone using Tapatalk |
Thank you all. I have redline in it currently, and it has whined a little in all gears. Bearings may have been some of the cause. It has the Toyota Certified Used 100k warranty so I should be good.
#6 | |
Yea, let us know what the problem is when you take it in! I'm curious to know what it is Sent from my iPhone using Tapatalk |
Alright. Dealership finally found out I have a Certified Used Warranty, and not a warranty purchased through finance. They called me today to authorize a "tear down" of the transmission. So if they don't find anything wrong, I'm on the hook for 10 hours of labor. The service advisor told me it was odd they were doing that.
Yaris grinding transmission warranty teardown synchros
Did "tear down" entity personally confirm symptom by test drive? If yes, how could there be "nothing wrong?"
| Breaking 2012 yaris 1.33 6 speed box | Affy87 | Items for Sale by private party | 6 | 02-07-2013 10:30 AM |
| 2012 LTA Land Speed Runs/Trails Harvest Event - new class record set | fnkngrv | Tracking, Racing, Auto-X Forum | 0 | 09-03-2012 07:30 PM |
| New 2012 Yaris L, 5 speed | KentSzabo | Third Gen Yaris General Discussion | 46 | 12-25-2011 12:08 PM |
| Test drive 2012 Suzuki SX-4 A.W.D.. : 6 speed manual and C.V.T. ( w/ manual shift ) | Hershey | Off-topic / Other Cars / Everything else Discussions | 7 | 09-30-2011 10:54 AM |
| Delay in picking speed and changing gears | zakasate | General Yaris / Vitz Discussion | 4 | 09-27-2010 11:57 PM |
