#1 |
![]() Drives: toyata vitz Join Date: Sep 2010
Delay in picking speed and changing gears
I have an automatic transmission Vitz and I am noticing that when i start off there is a delay in the picking up of speed. i checked the fuel filter i couldn't find one, i checked in the tank the mesh filter in the in the fuel pump it is OK. what could be the problem does this have to do with the fuel system or gear changing system? otherwise when it has picked speed everything is OK its just at the beginning
Drives: lil red 5-door Join Date: Sep 2006
throttle lag? we have electric throttles so there's always a bit of a delayed response, most noticeable in this situation of starting to get moving.
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#3 |
Drives: 2014 White VITZ Join Date: May 2007
Are you talking about taking off cold? When these cars are cold, acceleartion is slow and changing up gears lags. But, there should bo no problems when the car has reached running temperature.
#4 |
Slow in poicking speed
I found out that the Airflow sensor was dead. so i replaced it and everything is now ok.
#5 |
Glad you resolved the problem.
