Did you ever run the one from the japan?
If I could get the dimensions of the oem one I'm sure there are others that would fit into a Yaris control arm that are longer and correct the roll center. Jason, are you just using the oem ball joints?
I have not changed any of the joints or bushings, all OE. *Except the upper strut mount, replaced those marshmallow with the Cusco units.
| URGENT. BALL JOINT REINSTALLATION QUESTION | xb visitor | DIY / Maintenance / Service | 4 | 05-09-2014 06:02 AM |
| Wheel Bearing Replacement (FRONT) | justjesus | DIY / Maintenance / Service | 11 | 04-26-2014 07:38 PM |
| Front Lower Ball Joint Cotter Pin Replacment | GrayYaris | DIY / Maintenance / Service | 5 | 04-25-2014 04:30 PM |
| Putting on dust cover boot ring on ball joint | yaris4062007 | DIY / Maintenance / Service | 10 | 04-21-2013 12:51 PM |
| Ball Joint on Bottom Arm | David Godfrey | DIY / Maintenance / Service | 1 | 04-18-2010 06:27 PM |
