Old 04-21-2013, 03:14 AM   #1
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
Unhappy Putting on dust cover boot ring on ball joint
Is there special tool to install dust boot cover ring on ball joint?
yaris4062007 is offline   Reply With Quote
Old 04-21-2013, 03:15 AM   #2
yaris4062007
Old 04-21-2013, 03:23 AM   #3
yaris4062007
This happened after using ball joint fork
Old 04-21-2013, 03:25 AM   #4
yaris4062007
Old 04-21-2013, 07:43 AM   #5
Did you rip the new boot by trying to use the for to get that ring on?
I would probably try two pairs of locking pliers to hold the ends while pulling them apart to get the clip into place. There is a special tool for spreading that type of clip, but it may not be something that you could get from a local autoparts store.
Old 04-21-2013, 11:37 AM   #6
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
What Scott said. There are some special pliers. I've gotten them from sears before. Craftsman.
B2FiNiTY is offline   Reply With Quote
Old 04-21-2013, 12:27 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
I hate using pickle forks on the ball joint it always garentees you will damage the boot. This is the actual tool and brand I keep in my tool box for this job
http://www.youtube.com/watch?v=7vweCmGwBiU
Its about 20 bucks at harbor freight or around 50 for the entire master kit.
Old 04-21-2013, 12:40 PM   #8
yaris4062007
No, that's old stock boot and new one still good. I tried to spread using two locking pliers but it doesn't spread enough to fit. Looks like i need special tool
Old 04-21-2013, 12:41 PM   #9
yaris4062007
You got any picture what it looks like .
Old 04-21-2013, 12:42 PM   #10
yaris4062007
Yep I used that to remove it after fork failed
Old 04-21-2013, 12:51 PM   #11
yaris4062007
Can I use this to lubricate ball joint?? Thank you
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 06:27 PM
DIY Needed removal of entire e brake boot cover if it is possible? YarisSedan DIY / Maintenance / Service 5 12-18-2009 05:23 AM
07-08 Shift boot and ring schleppy Willing to Buy by private party 13 11-30-2009 03:06 AM
