Old 12-17-2009, 08:42 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
DIY Needed removal of entire e brake boot cover if it is possible?
I am looking to neffy wrap the handle of my e brake. But rather than start trying to cover up my interior and spray it with ahesive id like to pull it off do it in my garage let it dry and put it back on the car after its done.
Does anyone know if its possible to pull it off or its glued in place?
Old 12-17-2009, 11:14 PM   #2
1NZYaris1
1NZYaris1's Avatar
You talking about the rubber boot , if so yes it just pulls off .
run your fingers underneath it, it is split underneath
stick in fingers and pull apart carefully
Old 12-17-2009, 11:36 PM   #3
YarisSedan
Im talking about the boot and the plastic handle.
Old 12-18-2009, 12:17 AM   #4
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
thats easy u dont need someone to tell u how to do that its common sence brother but just to give u a start it starts from all the way back check for 2 bolts I dont remeber if the yaris has them
Originally Posted by sw07gt
Old 12-18-2009, 12:37 AM   #5
YarisSedan
Well i didnt feel like removing the exterior panel just to check if someone knew already if it came out. If the plastic housing is molded or glued to the metal e brake handle i figured someone might know. I tried to pull on it and twist it so figured it might be. Unless someone knows otherwise.
Old 12-18-2009, 05:23 AM   #6
1NZYaris1
1NZYaris1's Avatar
Pics from when i did ssk and h/boot
as for the plastic hand brake peice itself, i have never tried to take it off
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
