Have you checked the fuel system?
Pull the injectors and see if there's any abnormalalities. Can you check the afr sensor readings? |
#2 | |
![]() Drives: 2010 Toyota Yaris Join Date: Apr 2017
What exactly do I need to check in the fuel system? I have pulled off the fuel line and it delivers fuel while cranking, my obd doesn't have a afr listed on the live data, I havnt pulled the injectors yet but it's on the list of possibilities, problem I am having is 20 solutions to the symptoms but without a code telling me where to look into feel lost. Gonna try to post video of start up and obd2 readings. Rpms hover at 400 once warm. Not very tech savvy it seems gonna upload the videos to you tube and post link Video 1 https://youtu.be/PPYG15p-IMA starting Video 2 https://youtu.be/cEmcSt-J5yg obd2 Last edited by rangerkeim; 04-24-2017 at 08:19 PM. Reason: add videos |
| Car wont start - help! | tamo300 | General Yaris / Vitz Discussion | 14 | 03-23-2010 10:44 PM |
| Yaris does not start | jake002 | DIY / Maintenance / Service | 21 | 01-05-2010 08:53 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| Rough engine start w/76? | guyver408 | DIY / Maintenance / Service | 12 | 06-26-2009 12:18 AM |
| Rough Idle in drive | toyoman | NY / NJ/ CT / PA | 8 | 04-22-2007 03:40 AM |
