Old 04-24-2017, 11:18 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by rangerkeim View Post
is it normal for the fuel pump to only pump fuel when cranking and not when the key is turned on?
yes.
3.3v is running lean. It should be around 2.5V if your running regular gas.
Try unplugging the AFR sensor and see if your car runs better. If it's still the same, you'll have to check your fuel pressure with an in-line gauge you hook into the fuel line right at the fuel rail. From your description of having to crank for so long and running lean once running, it sounds like you have very low fuel pressure. The pump might have developed an internal leak or the built-in pressure regulator failed.
Old 04-25-2017, 12:04 AM   #2
rangerkeim
Drives: 2010 Toyota Yaris
Originally Posted by Bluevitz-rs View Post
yes.
Any idea where the afr sensor is on this model? I've been looking for schematics online but havnt found anything
rangerkeim is offline   Reply With Quote
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 08:53 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Rough engine start w/76? guyver408 DIY / Maintenance / Service 12 06-26-2009 12:18 AM
Rough Idle in drive toyoman NY / NJ/ CT / PA 8 04-22-2007 03:40 AM
