Old 04-26-2017, 10:08 AM   #1
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
Originally Posted by Pinchlite View Post
Those are the only pics I took.What exactly do you need help with?
Its so simple.I can take some more this weekend if you like.
Galvalized L brackets(Homedepot) screwed to floor,I used stubby hex head screws and had to drill larger holes into L breckets.Then mounted brackets to exsisting front flat parts on the bench suppports,used nut/bolt here.As you can see from pic I then used 2x3'S for cross members and again used large hex head screws.You just need to dry run everything and adjust accordingly for the depth/levelness of your top carpeted board.Once the top is on you can put the front skirt on.
I got carpet on Amazon and used 3M spray adhesive,cut wrapped board accordingly and stapled at back.
I cut and fit 6'' foam for underneath and the car is no louder then stock.
Very,very happy with how it looks and very sturdy,does not budge.
I left front part of stock bench support exposed purposely.Holds windex bottle,paper towel,etc upright perfectly.
P.S
I was not looking for more storage space or weight loss doing this mod but just wanted a nice clean looking totally flat hatch area.I suppose I lost some weight as the wood and L brackets dont weigh much.
I was looking at it on mobile and i guess not all the pictures where loading. Just opened it on my desktop, thanks!!!
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 04-26-2017, 04:17 PM   #2
Pinchlite
Drives: 2007 yaris HB
Make sure to post pics when done!
How to set up rear window wash sprayer? Be_Jammin DIY / Maintenance / Service 0 03-13-2016 05:40 PM
FS: 60/40 Split rear bench seat brushforhire Items for Sale by private party 9 08-14-2015 03:16 PM
Front seats instead of rear bench poorsh2 Cosmetic Modifications (Exterior/Interior) 5 06-17-2011 07:58 PM
