Old 03-13-2016, 05:40 PM   #1
Be_Jammin
Drives: 2010 Yaris Liftback A/T
How to set up rear window wash sprayer?
I bought a rear door for my hatchback with a window wiper + an intermittent stalk with rear wiper controls.
I have some questions:
1) How is the tube routed through the car to the rear?
2) How is washer fluid brought to the rear of the Yaris? I know via a tube obviously, but how is it pumped? Is a valve engaged to direct flow to the rear instead of the front via a split off? Or is there a valve in the sprayer on the window?
3) How is the tube connected to the reservoir? Split off of the front washer tube? Or a second connection to the tank?
4) I will need to join the cut hose at the rear door to new hose, does anyone know the best way to do this?
Be_Jammin is offline   Reply With Quote
hatchback, rear wiper, sprayer, washer, window wiper
Rear window washer - liftback boris13 DIY / Maintenance / Service 24 06-05-2007 04:20 PM
LB Rear Window Sprayer, spry or drizzle? dlinkwit27 DIY / Maintenance / Service 4 06-04-2007 09:49 PM
CAN TOYOTA RETROFIT NON-FIXED REAR WINDOW? pennsylvania girl Cosmetic Modifications (Exterior/Interior) 8 04-22-2007 01:47 AM
