Since the rear axle is solid beam, it is not really anti roll bar type sway bar like most are. So the results aren't going to be as dramatic or worth it like a typical sway bar.
IMO I think that money could be better spent on performance shocks/struts to match your springs. This greatly increased the handling on your car especially at high speeds. The sway bar is a good mod but for $400 and just regular non spirited daily driving you wont notice a big difference, just a bit more stability in the highway. If you drive hard and cornered hard during your drive then I'd say it's worth it
#2 | |
Anti Sway bar Yaris Corolla Tercel McPherson strut
So, Yaris has anti-sway at both ends. 91 fwd Corolla Wagon has no anti-sway, and softer spring rates. Works fine in all driving I've done. Just doesn't feel like a go-cart. Maybe better than Yaris on the high-crown gravel roads. (If anything I could see adding some light anti-sway at this Corolla's rear only for better peg-leg-differential traction.) Corolla got a version of this suspension after Tercel. (Stated reason was improved trunk space.) A circa 2005 one I saw had a visible solid bar inside a U-shaped channel for the cross beam. Tercel had just the U. I think rabbit had a T-section. Looks like yaris has a closed tube in a shape that is relatively soft in torsion? Last edited by dogsridewith; 05-18-2017 at 08:26 AM. |
#3 | |
Anti Swaybar Yaris Corolla Tercel rear suspension McPherson strut
I wrote "integral swaybar FUNCTION." Show any source calling this type of rear suspension not IRS. Or describing it as "solid beam."
#5 | |
Making a statement for the second time of Yaris' having independent rear suspension would require a source on your part to support your claim as it goes against what an irs set up looks and functions like. Lets keep the thread on topic for the op, if you want to discuss your interpretation of the rear suspension then by all means do so, but on your own thread
#6 | |
Toyota Yaris rear suspension
This is not off-topic. It will be fine for OP to know more about his suspension as he modifies it...particularly that it already includes some roll control. (In a very crude search of the Yaris rear suspension, I'm finding the terms "torsion beam rear suspension," and "semi-independent rear suspension." The main thing is to understand how it works.) Last edited by dogsridewith; 05-18-2017 at 04:45 PM. |
#7 | |
| Yaris Rear Driving Lights Problem | ap222 | DIY / Maintenance / Service | 3 | 05-31-2013 05:49 PM |
| Custom driving light install | Blue Y job | Photo-Video-Media Gallery | 3 | 10-03-2012 12:13 AM |
| "5 Driving Myths That Cost You Money" | PETERPOOP | Fuel Economy Forum | 10 | 05-24-2011 10:20 PM |
| Driving car at 75mph on position 3 :( | hans_fh | General Yaris / Vitz Discussion | 22 | 04-03-2007 04:09 PM |
| driving harsher..... | hoahmaru | General Yaris / Vitz Discussion | 7 | 04-09-2006 02:59 PM |
