Old 05-18-2017, 02:07 PM   #1
tmontague
tmontague's Avatar
Originally Posted by dogsridewith View Post
Show any source calling this type of rear suspension not IRS. Or describing it as "solid beam."
The responsibility of finding a source would land on you. The yaris lacks any type of rear control arms and both rear wheels are attached through a solid h style axle.
Making a statement for the second time of Yaris' having independent rear suspension would require a source on your part to support your claim as it goes against what an irs set up looks and functions like.
Lets keep the thread on topic for the op, if you want to discuss your interpretation of the rear suspension then by all means do so, but on your own thread
Old 05-18-2017, 04:00 PM   #2
dogsridewith
Drives: 2007 2-door hatchback
Toyota Yaris rear suspension
Originally Posted by tmontague View Post
....both rear wheels are attached through a solid h style axle.
The cross-the-car part of this piece isn't "solid". It is torsionally soft to do what a sway bar does. You might say it replaces separate trailing arms, two lateral links and a sway bar with a single piece. That was VW's invention, and why Toyota uses it.
This is not off-topic. It will be fine for OP to know more about his suspension as he modifies it...particularly that it already includes some roll control.
(In a very crude search of the Yaris rear suspension, I'm finding the terms "torsion beam rear suspension," and "semi-independent rear suspension." The main thing is to understand how it works.)
Old 05-18-2017, 05:16 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
So, if I'm comprehending, you (like Jason, the gentleman that is 2 Yaris race builds deep and who appears to have the most Yaris track time logged) would vote against adding a sway bar, correct?
On Instagram
On Wheelwell
Old 05-19-2017, 07:29 AM   #4
dogsridewith
Yaris rear swaybar torsion beam
Yes, for what I do with the car...it already feels like a go cart to me, and I want something that drives great on choppy off-camber tertiary roads, high crown gravel, and when you have to drop a wheel over the edge trap because something big oncoming is using most of the pavement.
For auto-crossing w/ pegleg differential, more rear swaybar would give more fwd traction.
Yaris Rear Driving Lights Problem ap222 DIY / Maintenance / Service 3 05-31-2013 05:49 PM
Custom driving light install Blue Y job Photo-Video-Media Gallery 3 10-03-2012 12:13 AM
"5 Driving Myths That Cost You Money" PETERPOOP Fuel Economy Forum 10 05-24-2011 10:20 PM
Driving car at 75mph on position 3 :( hans_fh General Yaris / Vitz Discussion 22 04-03-2007 04:09 PM
driving harsher..... hoahmaru General Yaris / Vitz Discussion 7 04-09-2006 02:59 PM
