Old 07-24-2017, 10:18 PM   #1
SirDigby
Drives: 2007 yaris 3 door
uh...that's really high tire pressure. since your city is at 249 feet (76m) i'd put them sticky shits at 28psi-30psi (193kPa-207kPa)
do you have a print out of your alignment? sounds like a toe issue maybe. are the tires rotating the correct direction? sometimes tires mounted in the wrong direction will have this effect.
there is differently something wrong. did you install adjustable sway-bar end-links with your drop? what brand of strut/shock/springs?
i do that speed everyday, stock suspension with 80,000 miles (128,750km) on them. (upper strut brace, rear sway bar have no effect on straight line) feels comfortable all the way to 112mph. (180kmh)
Old 07-26-2017, 06:38 AM   #2
Pinchlite
Drives: 2007 yaris HB
Not sayng its uncomfortable.The car stays true as in zero pull.No vibrations.
New Tires are on correct with new KYB shocks.
I ckecked pressure cold last night 32 all round.These are not super sticky tire and many use this exact tire and are pleased as am I.
Perhaps Iam just not used to the yaris at higher speed?
The car drives absolutely firm amd feels really responsive.Really,really impressed overall.Drives nicer then a new fit and civic si which are both 2016 and I have driven both.
The civic feels like a boat and the fit just feels cheapish,kind of like a chevette,pontiac acadian or escort I once owned.
Could a bad stabilizer bar(One that connects to front shock absorber) cause issues like I described.
I think that is rattling.
I have new cv drive shaft going in this weeekend due to torn boot so i will have mechanic give it a thorough go over.
Just filled up the tank with 91 octane premium fuel darkmoon87 General Yaris / Vitz Discussion 105 10-02-2016 08:35 PM
How about higher speeds? BensVitz General Yaris / Vitz Discussion 25 05-10-2006 10:09 AM
