Old 07-24-2017, 10:18 PM   #2
SirDigby
Drives: 2007 yaris 3 door
uh...that's really high tire pressure. since your city is at 249 feet (76m) i'd put them sticky shits at 28psi-30psi (193kPa-207kPa)
do you have a print out of your alignment? sounds like a toe issue maybe. are the tires rotating the correct direction? sometimes tires mounted in the wrong direction will have this effect.
there is differently something wrong. did you install adjustable sway-bar end-links with your drop? what brand of strut/shock/springs?
i do that speed everyday, stock suspension with 80,000 miles (128,750km) on them. (upper strut brace, rear sway bar have no effect on straight line) feels comfortable all the way to 112mph. (180kmh)
Just filled up the tank with 91 octane premium fuel darkmoon87 General Yaris / Vitz Discussion 105 10-02-2016 08:35 PM
How about higher speeds? BensVitz General Yaris / Vitz Discussion 25 05-10-2006 10:09 AM
