Old 07-26-2017, 08:32 AM   #17
tmontague
tmontague's Avatar
It's likely the fact that the yaris is such a light car than many others that you're used to. I found running wider tires, rims with a wider offset and more negative camber helped a lot for high speed stability.
I run 40/36 f/r for tire pressure. Mainly because I travel a lot of km's a year and I found anything less caused ore nature seat on the shoulders of the tire relative to the middle. Any pressure higher than that and the bride was too rigid
Just filled up the tank with 91 octane premium fuel darkmoon87 General Yaris / Vitz Discussion 105 10-02-2016 08:35 PM
How about higher speeds? BensVitz General Yaris / Vitz Discussion 25 05-10-2006 10:09 AM
