Old 07-26-2017, 08:32 AM   #1
tmontague
tmontague's Avatar
It's likely the fact that the yaris is such a light car than many others that you're used to. I found running wider tires, rims with a wider offset and more negative camber helped a lot for high speed stability.
I run 40/36 f/r for tire pressure. Mainly because I travel a lot of km's a year and I found anything less caused ore nature seat on the shoulders of the tire relative to the middle. Any pressure higher than that and the bride was too rigid
Old 07-26-2017, 06:18 PM   #2
Check Tha Rook
Drives: 2008 Toyota Yaris hatchback
How wide of a rim would will fit on the yaris without sacrificing functionality?
Check Tha Rook is offline   Reply With Quote
Old 07-26-2017, 07:11 PM   #3
tmontague
tmontague's Avatar
If you never want to worry about rubbing you can easily for a 6.5 inch wide with a +28 offset with 185 wide rubber. You'll also have more space for a wider tire on that set up.
Keep in mind this is with -2.8 camber front and -1.8 rear on lowering springs
I have also had 7inch wide +25 in the rear with 195 side r comp rubber and they rubbed by 1mm on the inner metal of the fender. I'll be rolling that to alleviate this issue.
So in short, 6.5 wide with +28 offset will be fine if you have camber bolts up front and a camber washer in the rear
Old 07-26-2017, 11:37 PM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
7 inches, +42/+38 offset is a nice happy place.
Old 07-28-2017, 05:43 PM   #5
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I run 40/36 f/r for tire pressure. I found anything less caused ore nature seat on the shoulders of the tire relative to the middle.
? Can we have the auto correct translation?
Next time try plying her with alcohol.
Old 07-28-2017, 05:45 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
Thanks for the laugh!
Just filled up the tank with 91 octane premium fuel darkmoon87 General Yaris / Vitz Discussion 105 10-02-2016 08:35 PM
How about higher speeds? BensVitz General Yaris / Vitz Discussion 25 05-10-2006 10:09 AM
