#1 | |
![]() Drives: 2008 Toyota Yaris hatchback Join Date: Jul 2017
#2 | |
Keep in mind this is with -2.8 camber front and -1.8 rear on lowering springs I have also had 7inch wide +25 in the rear with 195 side r comp rubber and they rubbed by 1mm on the inner metal of the fender. I'll be rolling that to alleviate this issue. So in short, 6.5 wide with +28 offset will be fine if you have camber bolts up front and a camber washer in the rear
| Just filled up the tank with 91 octane premium fuel | darkmoon87 | General Yaris / Vitz Discussion | 105 | 10-02-2016 08:35 PM |
| How about higher speeds? | BensVitz | General Yaris / Vitz Discussion | 25 | 05-10-2006 10:09 AM |
