Old 08-08-2017, 02:45 AM   #1
laobo
Drives: yaris sedan 2011
Hi friend. Did you have? Review your final
Originally Posted by Eduardo_mty View Post
Thank you, i will do tomorrow
I will do....
1. Remove the negative wire from battery.
2. Remove the EMC Connector.
2.1 remove the waterproof Rubber plug
2. 2 install a wire
3. Reconnect the EMC connector
4. Reconnect negative wire to battery
5. Turn on the key
5.1 check wire voltage , if show 12v, it will work
This is the steps that i will do, its ok
Can you show me. which is number pin of ECM ( ECU) for signal ccs ?
my car is 2014-2017 year
laobo is offline   Reply With Quote
I want to add cruise control on my 2009 yaris doorslammer DIY / Maintenance / Service 1 08-20-2015 01:28 PM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 09:09 AM
