Old 11-28-2015, 10:23 PM   #16
Eduardo_mty
Thank you, i will do tomorrow
I will do....
1. Remove the negative wire from battery.
2. Remove the EMC Connector.
2.1 remove the waterproof Rubber plug
2. 2 install a wire
3. Reconnect the EMC connector
4. Reconnect negative wire to battery
5. Turn on the key
5.1 check wire voltage , if show 12v, it will work
This is the steps that i will do, its ok
Eduardo_mty is offline   Reply With Quote
I want to add cruise control on my 2009 yaris doorslammer DIY / Maintenance / Service 1 08-20-2015 12:28 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
