Old 08-30-2017, 11:44 AM   #1
DarkShadowFox
Originally Posted by cdydjded View Post
Let me clarify when I say the 1ZZ's are to big. In my car, with no correction from the AEM FIC, it runs very rich. You can see what Im talking about in my profile pics of my dyno. With that being said, of couse you can use the AEM FIC to correct that problem. But here is the issue, you would have to use 1 of the fuel maps based upon TPS sensor input to correct the fuel trim when not in boost & the MAP sensor which is built into the AEM FIC to correct the fuel trim while under boost. That get very complicated & you need to find a really good tuner for that. AEM even suggests to use only 1 fuel map if possible to simplify tunning.
With that being said, I suggest finding an injector that is between the stock one's (190cc) & the 1ZZ (220cc) to make tuning much easier.
Should I run the F/IC-6 with 2zz or 1zz injectors?
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
FS: 05 1zz t/b and injectors OTA'sTOY Items for Sale by private party 4 06-03-2010 08:07 PM
1ZZ Injectors on NA Setup MGargano Performance Modifications 14 04-22-2010 01:02 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
