Old 09-02-2017, 07:32 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Something is off here, my stock injectors maxed out at a much higher hp than yours. I'm not going to give out numbers but I was making at least 30% more power than you on the stock injectors with no issues, it also looks like VVT isn't working on your car which will cost you about 20lb\ft of torque below 5k. Rather than fight with the emanage ultimate it would be easier to pickup a EMS4 and use that since it'll be less problematic and you won't have to fight with the ECU tuning you out.
2014 BSpec Divisional Champion
Old 09-02-2017, 07:40 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
You running E85 too?
Old 09-02-2017, 08:19 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
Nope 100 oct race fuel
Old 09-02-2017, 08:44 PM   #4
Bluevitz-rs
E85 requires an A/F of around 9:1 I think so that's why he's running out of injector long before you on regular 100% gasoline.
Old 09-02-2017, 11:04 PM   #5
rabbito
rabbito's Avatar
the dude with same cam as mine with standalone ecu, 1zz intake manifold conversion with 60mm throttle body woth custom intake(box) and exhaust job makes 130whp on the dyno...if you said your making 30% more than i do(which is about 130whp) with stock injectors, just a cam and ecu? thats too much of a magic number..correct me if im wrong please...
i am going to check some stuff out
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Old 09-02-2017, 11:21 PM   #6
xnamerxx
0-60 in slow
xnamerxx's Avatar
Well I'm making more than that, but I'm on the stock intake and stock throttle body, but I do have a header, cams, 11:1 compression, and some other internal magic. I would probably make quite a bit more power if I was allowed to run a bigger intake or throttle body as I'm developing about 3" of vacuum at 8k where the intake is basically acting as a restrictor.
Granite State Dyno & Tune Open House fnkngrv New England 0 03-18-2014 11:35 AM
N/A performance tune yaris2010RS Performance Modifications 3 12-13-2012 01:33 AM
Tiamat 10 July 12 Dyno Tune and Results - Stock motor top speed found fnkngrv Forced Induction Forum 4 10-06-2012 11:00 PM
Dyno results PETERPOOP Forced Induction Forum 28 12-09-2009 11:01 AM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
