Old 09-02-2017, 07:40 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by xnamerxx View Post
Something is off here, my stock injectors maxed out at a much higher hp than yours. I'm not going to give out numbers but I was making at least 30% more power than you on the stock injectors with no issues, it also looks like VVT isn't working on your car which will cost you about 20lb\ft of torque below 5k. Rather than fight with the emanage ultimate it would be easier to pickup a EMS4 and use that since it'll be less problematic and you won't have to fight with the ECU tuning you out.
You running E85 too?
Granite State Dyno & Tune Open House fnkngrv New England 0 03-18-2014 11:35 AM
N/A performance tune yaris2010RS Performance Modifications 3 12-13-2012 01:33 AM
Tiamat 10 July 12 Dyno Tune and Results - Stock motor top speed found fnkngrv Forced Induction Forum 4 10-06-2012 11:00 PM
Dyno results PETERPOOP Forced Induction Forum 28 12-09-2009 11:01 AM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
