Old 09-08-2017, 09:52 AM   #3
bronsin
bronsin's Avatar
First thing you do is to lube the locks! For your problem dry graphite might not work as well as graphite that comes mixed with a liquid lubrication. I personally use White lithium spray lubricant sold by the makers of liquid wrench. Be careful not to spray too much because it will run down the side of the door. I think lubing the locks will fix your problem.
Good luck and tell us what happens!
New remote key fob programming costica DIY / Maintenance / Service 1 04-17-2016 08:02 PM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
key wont turn out of lock position Drummer829 DIY / Maintenance / Service 10 09-22-2012 01:34 PM
2007 Yaris Door Lock Issue bhola General Yaris / Vitz Discussion 7 10-05-2010 12:01 AM
Driving wheel doesn't lock when taking off the key Pingouin General Yaris / Vitz Discussion 5 09-08-2010 11:15 PM
