First thing you do is to lube the locks! For your problem dry graphite might not work as well as graphite that comes mixed with a liquid lubrication. I personally use White lithium spray lubricant sold by the makers of liquid wrench. Be careful not to spray too much because it will run down the side of the door. I think lubing the locks will fix your problem.
Good luck and tell us what happens!
| New remote key fob programming | costica | DIY / Maintenance / Service | 1 | 04-17-2016 08:02 PM |
| Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 06:32 PM |
| key wont turn out of lock position | Drummer829 | DIY / Maintenance / Service | 10 | 09-22-2012 01:34 PM |
| 2007 Yaris Door Lock Issue | bhola | General Yaris / Vitz Discussion | 7 | 10-05-2010 12:01 AM |
| Driving wheel doesn't lock when taking off the key | Pingouin | General Yaris / Vitz Discussion | 5 | 09-08-2010 11:15 PM |
