![]() ![]() Drives: 2016 5 dr Yaris LE Join Date: May 2013
Third Gen TPMS Light
Does the 2nd gen TPMS light wiring hack work on the newer cars?
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
![]() ![]() ![]() Drives: 2016 Yaris 3 Dr Super White Join Date: Mar 2016
PCV Container hack. 8 inch PCV Pipe, capped at both ends, put sensors in the pipe before capping, put in trunk. Done.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Either the batteries in the sensors go flat, or the owner has separate sets of wheels and tyres for Summer and Winter.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#6 | |
On the 2nd gen cars, there is a wire that can be spliced into another wire that will defeat the TPMS warning permanently. I used that hack on my 2nd gen car and I'm asking if that same fix will work on the 3rd gen cars. |
Once you put the right amount of air into the tube, the TPMS will still read the correct tire pressure, but it'll be from the tube. Then you throw it someplace in the truck and the system will be tricked into thinking the the sensors are in the tire. You can swap wheels and tires to your hearts desire at that point. It's just another work around, if someone chooses to do it that way.
#8 | |
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback Join Date: Jul 2016
Could always use a techstream to zero out all the sensor codes? Not sure if that would work or not
-Karl the Uber/Lyft Driver |
![]() ![]() Drives: 2015 Yaris L Join Date: Jun 2017
Here is a post from Ctscott, who seems to be a real crackerjack so I will assume he is correct:
"There is not a simple solution for 3rd gen (2012+), as the TPMS ECU now sends the info to the cluster via CAN bus message, rather than by a simple single line driving an LED. The third gens do allow you to easily relearn the TPMS sensors by simply pressing a button, so the simplest solution is to have a second set of sensors in your alternate rims." So I guess no wiring hack available, at this time, for 3rd gen owners. |
#11 | |
Looks like I'll have to remove the tpms and do the pvc tube thing until it's time for new tires. |
#12 | |
You can try doing the relearn procedure with the tire sensors away from the car and it might shut the light off.
#14 |
I fitted new wheels/tyres the day I got my car and chose not to install the TPMS in the new wheels. The sensors are sitting in my garage, and the dash light has been on ever since. Doesn't bother me at all.
#15 |
#16 |
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
My TPMS works really wel and is totally reliable. I just go round the tyres every week with an accurate pressure gauge.
#17 |
my tpms is broken on my 3rd gen. it doesnt read and my tires sometimes get flat. :c
#18 |
![]() Drives: 2012 Yaris 3d LB Join Date: Feb 2017
Black tape or taking the bulb out might help.
| SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! | tylerwatts53 | DIY / Maintenance / Service | 1 | 07-17-2014 08:53 AM |
| 2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) | nookandcrannycar | General Yaris / Vitz Discussion | 7 | 02-22-2014 08:16 PM |
| TPMS light on after swapping 1 tire from different car | nvidiaxtc | DIY / Maintenance / Service | 5 | 02-02-2011 09:45 PM |
| HELP / Spoiler connecting light | SimTronik | DIY / Maintenance / Service | 4 | 11-02-2010 11:08 PM |
