Old 09-16-2017, 08:51 PM   #1
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by MugenRep View Post
- Installed WITHOUT adjusting at idle for 20 mins while it went through looking at and trying to learn the new throttle body.
-After it fluctuated for 20 mins. I adjusted the screw 2.5 turns counter-clockwise (I think). Then restarted and let it go through procedure again until the idle calmed down.
the screw you are adjusting is the cold idle screw. it is easier to adjust when the engine is cold.
another option is the sprint booster. it's advantage, besides acceleration increase, is a valet mode and a "lock out" security feature. they are pretty neat.
www.sprintbooster.com
Old 09-17-2017, 06:06 AM   #2
miiser
miiser's Avatar
Drives: yaris 2009
1NR-FE Engine tunes-mods-etc.
Wow it's made in my country too. I didn't expect that. I will check this out
I checked it
So it's just to reduce the throttle lag?
miiser is offline   Reply With Quote
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
Engine rebuild or engine change? big dilemma.... Elwe2k DIY / Maintenance / Service 28 02-02-2017 10:21 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Engine mods - why bother? RallyYaris Performance Modifications 143 12-24-2006 03:56 AM
