#1 | |
iQ innovator & researcher
Drives: 2012 iQ Join Date: Mar 2016
According to the member who had his header custom made, it worked and added more power overall, which I'm sure is true since he deleted his primary catalytic convertor. Here's some pics of the header compared to stock as well as the Group I saved info to. If you look under photos and albums, you'll see categories and info I've found associated with the engine and iQ chassis. |
#2 | |
![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
1NR-FE Engine tunes-mods-etc.
Nice one. Did you made the header custom made? Or you purchased it? And how much it costs? Also how much more loud with single header swap the car can be? Also can you explain me what the camcon does? I just searched about it and it seems very interesting. Is it easy to use? Sent from my iPhone using Tapatalk |
#3 | |
The header was made by a local welder for the member for $200 USD, and his iQ isn't too much louder than and iQ with a DC Sports cat-back and OEM catalytic convertors. The CamCon really honestly needs at least a wide-band o2 sensor to make sure you don't run too lean and dyno tuning for best gains. It allows you to adjust VVT-I timing on the fly to and as well as alter A/F curves throughout the rev range to optimize performance based on octane and modifications. Until you'd get a tune, you can just set the 1NZ-FE settings into and and turn it on when or if needed If CamCon isn't to your liking, you could buy one of Sangawa-Sans MiniCons which do almost the same thing. http://www.t-san9.com/parts.html |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 31 | 10-20-2025 09:08 AM |
| Engine rebuild or engine change? big dilemma.... | Elwe2k | DIY / Maintenance / Service | 28 | 02-02-2017 10:21 PM |
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| Engine mods - why bother? | RallyYaris | Performance Modifications | 143 | 12-24-2006 03:56 AM |
