Old 04-29-2007, 07:01 AM   #1
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
trd shocks *update with pics*
hey guys, planning on installing my trd shocks and springs later on 2day. would i need to save the old bump stops from my stock setup or are they supplied in the box. i have not opened it yet so i really dont know. would they have to be cut as well?
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 04-29-2007, 09:14 AM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Blenjar says he called Toyota and they said to cut. I'm still kinda surprised that Toyota told him to cut but apparently that is what they said. There are not different bump stops in the box.
SPONSORED BY
Old 04-29-2007, 10:47 AM   #3
Ran Kizama
That Anime Guy
Ran Kizama's Avatar
Drives: 5-Speed Liftback
Send a message via AIM to Ran Kizama Send a message via MSN to Ran Kizama
There are not new bump stops in the box. Use your old ones. I asked my tech at Toyota here and he said to not cut the bumpstops. The shocks are designed to work with the factory bumpstops.
Ran Kizama is offline   Reply With Quote
Old 04-29-2007, 01:29 PM   #4
brickhardmeat
Lonesome Cowboy
I would opt not to cut myself. However, this is something that there seems to be a big difference of opinion on.
SPONSORED BY
Old 04-30-2007, 10:16 AM   #5
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
No opinions. TRD's are a matched set, designed to work together. No bump stop cutting required.
Every other single spring ONLY change you make, needs the bump stop to be cut to their spec's when lower with STOCK ORIGINAL struts and springs.
Guys are talking out their ass on the topic, because they have no clue what they are talking about... again, like you said, "OPINION," not facts are being talked about.
Old 04-29-2007, 01:35 PM   #6
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
do NOT cut. i have these installed and we used the originals.
i repeat. DO NOT CUT.
tekmoe is offline   Reply With Quote
Old 04-29-2007, 01:37 PM   #7
brickhardmeat
Lonesome Cowboy
I hope he's not out there cutting them right now.
SPONSORED BY
Old 04-29-2007, 02:52 PM   #8
sdmf
sdmf's Avatar
thanks guys, well im off to get my car slammed
Old 04-29-2007, 02:59 PM   #9
brickhardmeat
Lonesome Cowboy
we wanna see some pics later
SPONSORED BY
Old 04-29-2007, 03:03 PM   #10
07typeS
07typeS's Avatar
Drives: 2007 White Toyota Yaris Type S
Send a message via AIM to 07typeS
only takes a couple hours....see you back in a bit....
TRD Springs w/ KYB Struts and Shocks, Custom CAI w/ K&N filter and pre filter wrap, Weapon R Header, Stock 15 inch alloys, Dezod Performance pads, Tanabe Front Strut Bar, 35% front door Tint and 20% Rear doors back Tint, De-Badged Ass, Custom painted flat black interior, Pioneer deh-p6700bt w/ IPOD hookup, Infinity components up front with custom mounted tweeter, Inifinity 6x9's out back, 1 12" kicker comp cvr........
07typeS is offline   Reply With Quote
Old 04-29-2007, 04:06 PM   #11
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Good Luck... Can't wait to see!
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Nutzoids is offline   Reply With Quote
Old 04-30-2007, 06:02 AM   #12
sdmf
sdmf's Avatar
ug
well there was alot of cars 2day that were to be worked on, i was only able to get the front shocks and springs, heres some pics, notice i had a lovely assistant and other friends helping me out. just waiting for it to settle, anyway i ordered the trd rear sway bar. so hopefully i can finish everything this week.
Old 04-30-2007, 08:37 AM   #13
hot chick wrenching on a Yaris? ultimate turn-on!
Old 04-30-2007, 10:26 AM   #14
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
I spoke to 3 Toyota Guys. 2 at Spark and 1 at my dealership. The one at my dealership has obviously a Toyota with TRD spring, his son too (xA). both cut the bump stop.
The Spark guys said they also cut the bump stop.
I cut mine too at the first U...ride is just low and bounces really smoothly...
Hey cut it or not, its koo..its probably a preference thing.
-- Blen
Old 04-30-2007, 10:54 AM   #15
Chris07LB
Chris07LB's Avatar
-- Blen
First, go learn the purpose of a bumpstop. It's not a "preference thing."
Blen here's an example, if say you did DF's and DIDNT cut the bumpstops, (as recomended by Tanabe) and just left them stock, your suspension is now 2" lower then stock, using stock struts.. with me? Now, that first big ol pothole you enter, or rut in the road, your suspension travel is now limited to how much it will compress, because the bumpstops will be the first to make contact. By cutting the bumpstop the recomended amount, your suspension will be able to compress enough to where the shocks/struts won't bottom out, but also to where every hard hit will be absorbed by your suspension.
Facts to keep in mind is, spring rate as every brand is different, and also how much weight is going to be in the car at times... extra people or just packing it full of supplies.
I have installed MANY suspensions over the years.. from static dropped spring kits, to full on air suspension's and lift kits.
Brands recomending cutting bump stops from my first hand experience, using stock struts and or shocks?
H&R
Intrax
Ebiach
PRG
Tanabe
Sprint
B+G
Ground Force
Call your SPRINGS manufacturer if unsure!
Old 04-30-2007, 01:49 PM   #16
brickhardmeat
Lonesome Cowboy
Yes, I e-mailed Tanabe just to see what response I got...
Me "I have a set of DF210 springs and I am getting ready to install them on my 2007 Toyota Yaris lift back. Would you recommend cutting the bump stops?"
Tanabe USA "I would cut 1" off the bump stop."
I'll probably just buy a set of the shorter bump stops that I saw recently because I would end up with a "hack job" attempting to cut mine.
by the way the car looks good! it will be interesting to see how much it settles but it looks like a healthy sporty kinda stock drop, probably will ride quite nice too, let us know what you think as you try it out
SPONSORED BY
Old 04-30-2007, 02:47 PM   #17
Chris07LB
Chris07LB's Avatar
Brick - look in my DIY Spring How_To.
Cutting the bumpstops is CAKE! I used just a hacksaw blade, but a normal dinner knive will also make quick work of it.
Old 04-30-2007, 06:35 PM   #18
brickhardmeat
Lonesome Cowboy
I used your DIY to install my temporary set up and I'm sure I'll use it again this next time around made things very easy. Thanks.
I still might buy the shorter ones so I can keep the stock set. I might want to do something different later.
SPONSORED BY
Fs: New Trd Stickers & Emblems !!!!! located in So cal Trd86 Items for Sale by private party 13 06-25-2007 05:49 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 11:51 AM
Tein S.Tech, TRD shocks, Tanabe strut bar review Kaotic Lazagna Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 04-16-2007 01:41 AM
TRD SHOCKS will fit yaris sedan 4 (doors)??? mariosuper Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-07-2006 12:36 PM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 01:42 PM
