Replaced Downstream O2 Sensor
I've had a check engine light on since I bought the car. According to Torque Pro OBD2, I had zero volts on the bank 1 sensor 2. So, I replaced the sensor today and was disappointed that it still read 0 volts while idling in my driveway, however the MIL did not return. But I went for a drive and now it works. Getting a good sweep from 0.1 to 0.9 volts and air fuel ratios, commanded and measured, are perfectly in sync. I found the answer on another Toyota model car/truck forum.
Anyone want to guess why it didn't appear to work at first?
maybe when it was in open loop it had not sent voltage to sensor yet. (?)
#3 | |
But, it sounds like you are on the right track in that it did not show a voltage until a certain condition was met. What condition do you think that was? It is different than my Kia's sensors as they will start to show fluctuating voltages from the 02 sensors as soon as it's started.I don't know much about vehicle electronics. Wish me luck as I paid $18.00 USD on eBay for this sensor. It's a cheap knockoff, but seems to work - so far anyway.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-25-2017 at 10:26 PM. |
The sensor needs to heat up before it works. O2 sensors create their own voltage, so what you're reading isn't anything sent from the computer. It only reads what the sensor sends it.
#5 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
O2 Sensor downstream connection location?
I have multiple faults and I think it’s my downstream O2 sensor that’s most likely the culprit. I went underneath the car, but the connection leads inside the cabin. Where is it exactly located?
Thanks Adam
#8 | |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
start saving for an oem sensor, i replace tons of aftermarket sensors on customer cars coming to the dealer complaining another shop fixed their car a month ago and it has the same error codes back on again
| DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS | auxmike | DIY / Maintenance / Service | 50 | 12-10-2024 12:39 PM |
| Rear Speed Sensor Install Help? (ABS Sensor) | towerofpower | DIY / Maintenance / Service | 2 | 04-07-2014 06:32 PM |
| Upper O2 sensor replaced but did not fix the problem | Hard_Yaris | DIY / Maintenance / Service | 9 | 04-10-2013 10:22 AM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
