Old 09-25-2017, 10:41 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The sensor needs to heat up before it works. O2 sensors create their own voltage, so what you're reading isn't anything sent from the computer. It only reads what the sensor sends it.
Old 09-25-2017, 10:59 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yes! I read that it has to reach, I believe, 600F before it sends voltage. Thanks for playing, both of you!
Old 03-01-2021, 06:53 PM   #3
Neinris
O2 Sensor downstream connection location?
I have multiple faults and I think it’s my downstream O2 sensor that’s most likely the culprit. I went underneath the car, but the connection leads inside the cabin. Where is it exactly located?
Old 03-01-2021, 10:52 PM   #4
Neinris
Thanks Adam
Just want to share the youtube video you sent me:
https://www.youtube.com/watch?v=yT5Wgs1b6wg
Old 03-02-2021, 07:06 AM   #5
06YarisRS
Glad it helped you!
DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS auxmike DIY / Maintenance / Service 50 12-10-2024 12:39 PM
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 06:32 PM
Upper O2 sensor replaced but did not fix the problem Hard_Yaris DIY / Maintenance / Service 9 04-10-2013 10:22 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
