Old 09-26-2017, 09:44 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
actually many asians in asia shift through gears on automatic tranny including myself...i feel like people here have more knowledge than people in the states...
how and why? set your standaline or piggyback ecu to pass 7,000rpm (mine goes up to 7,300rpm with cams) and reset the fuel cut etc, shift from L-2-3..auto 5 speed will shift when it reach 6,000 something rpm just pass through gears or slip(thats what they call here where gears searching) so they use the L-2-3...this is what i exactly do in the video below...
Youtube video search:
1/4 mile drag racing by smallroom vios
Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Car will shift into gears (manual transmission) but won't move kustomrtr DIY / Maintenance / Service 4 04-11-2017 01:44 PM
Straight Cut Gears ACKING_QC Performance Modifications 3 01-30-2017 09:29 PM
yaris 2009 MMT-problem in shifting gears. matanfr DIY / Maintenance / Service 8 06-30-2010 02:37 AM
Stiff gears after a while juxtapozed General Yaris / Vitz Discussion 10 05-05-2010 05:37 PM
