Old 10-07-2017, 07:07 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
All 06+ Yaris have it. Not sure about the gen2 or gen3, but I'm pretty sure they are.
You don't even need to hold it for 1s. Just flick it as if you pushed a start/stop button.
Mine takes a tiny bit longer to start since I changed the battery. I wouldn't worry if it doesn't overcrank.
And seriously? More wear on the starter? Do you push the hand brake button as you engage it, so you don't wear the clicker?
Sent from my SM-G930W8 using Tapatalk
Old 10-07-2017, 09:23 PM   #2
BennyLava
Drives: 1987 Silverado
Who said more wear on the starter?
Although yes, the more a starter is used, the more wear it sees. You don't wear out a starter that never gets used and sits on a shelf.
BennyLava is offline   Reply With Quote
Old 10-09-2017, 02:13 AM   #3
I know the third gens removed that feature.
Old 10-09-2017, 03:03 AM   #4
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Correct. No crank and hold on 3rd gen cars (or at least on mine).
Old 11-07-2017, 06:37 AM   #5
BennyLava
Well its doing it more and more often now. Its the wife's car that she drives to work every day. Although its also something of a shared car between us, since my 87 silverado gets a pitiful 15mpg. So I also use the car a good deal.
She's becoming concerned about it, because its doing it more and more and its doing it for longer. Is there anyone here who is really clear on what causes this?
Hard starting when cold, runs fine Kubcat DIY / Maintenance / Service 6 01-03-2022 08:58 AM
intermittent hard starting Ramon1691 DIY / Maintenance / Service 17 07-20-2016 12:49 AM
Toyota yaris 2002 - Hard clutch abhinav_kr DIY / Maintenance / Service 10 06-29-2016 07:08 AM
yaris hard starting when hot, fine when cold ianpog DIY / Maintenance / Service 11 08-12-2015 09:24 PM
Hard braking? abdallah380 General Yaris / Vitz Discussion 2 07-26-2010 01:37 AM
