Old 10-07-2017, 08:11 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
You often see back window bubble up. These installers used crappy tint film typically don't warranty it.
Both my cars were done and carry life time warranty. Not like I will ever need it. They stand by their work, and it's good.
Sent from my SM-G930W8 using Tapatalk
Old 10-07-2017, 08:40 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Whether I attempt the install myself - seller is sending me another kit - I will not be doing the rear (liftgate) window. The tint job is mainly to reduce the sun in the light in the rear seats. Kids will drive us crazy if there is too much 'screen glare'. :) I expect that in the end, I'll probably end up going with the pros. Thanks.
DIY - OEM Power Window Conversion CTScott DIY / Maintenance / Service 29 10-28-2024 12:02 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 11:03 AM
DIY: How to remove window tint cali yaris DIY / Maintenance / Service 4 07-30-2012 03:18 AM
Replacing my aftermarket window tint. Herbicidal Cosmetic Modifications (Exterior/Interior) 11 07-19-2010 12:56 AM
DIY Window Tint films from Walmart Dec24th Cosmetic Modifications (Exterior/Interior) 14 01-15-2010 01:28 PM
