Old 07-25-2012, 12:26 PM   #1
DIY: How to remove window tint
Here is a great way to remove tint with very little work.
1. Spray Windex or straight ammonia onto the window (use a LOT)
2. Open up a Hefty bag or similar and tape it around the edges, 100% sealing the Windex inside. Black plastic side facing the window is best.
3. Pull out a little section of tape, and spray more Windex in there. Seal it back up.
4. Park in the sun with the window facing the sun.
5. Let bake one hour, or until a toothpick comes out clean. (just kidding about the second part). Your window should be very hot to the touch!
6. Remove the plastic and peel off your tint.
7. While still hot, use the Windex and a microfiber (or whatever) to wipe whatever glue residue is left. This is much easier when it's warm or hot. You can use a heat gun if it cools off.
Ammonia will infuse into the film and release the glue beneath. The tint will peel off in one piece if you take your time and pull at a 45 degree angle.
Couple of pics:
Old 07-25-2012, 02:47 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
great!
Old 07-25-2012, 04:50 PM   #3
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I was able to pull my tint off without leaving a speck of glue residue...I'd suggest people give it a try then go forward with the sure thing Garm posted.
-Type 07 FFL-
My odometer 03/11
Old 07-30-2012, 01:55 AM   #4
BLITZEN
Drives: 2008 yaris rs
nice !!
BLITZEN is offline   Reply With Quote
Old 07-30-2012, 02:18 AM   #5
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Yeah . . we should all remove our tint now. Love the thread.
edmscan is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Replacing my aftermarket window tint. Herbicidal Cosmetic Modifications (Exterior/Interior) 11 07-18-2010 11:56 PM
DIY Window Tint films from Walmart Dec24th Cosmetic Modifications (Exterior/Interior) 14 01-15-2010 12:28 PM
