Did they indicate if it was the upstream (wideband) sensor, or the downstream (post-cat) sensor? The upstream sensor measures air/fuel ratio, the downstream sensor measures residual oxygen after the exhaust has passed through the cataylic converter. Upstream sensor = more expensive, can affect driveability, fuel economy, downstream sensor = less expensive, should have no effect on driveability. It is an easy DIY job but finicky. The hardest part I found was getting up into the car and unclipping the connectors. I bought a very cheap (~$17.00) downstream sensor, but wouldn't have cheaped out on the upstream if I had had to replace it.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-07-2017 at 04:22 PM. |
#2 | |
![]() ![]() Drives: Toyota Yaris 2007 Sedan Join Date: Sep 2017
He opened the hood to show me where it was, just behind the engine. I'm beginning to think I should take the car somewhere else. Are you saying that there are two? Mine is the 4 speed automatic |
#3 | |
On my model there are two o2 sensors. Not certain about your car. If it is right behind the engine, it is probably the upstream sensor. I'm going to defer to others here that are much more knowledgeable than I. Also, not sure what impact leaded fuel would have on the emission system or other systems.
![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
How much did he quote you for the repair? He didnt mention which sensor? There are cheap ones you can buy online but personally, I would get something branded if you can, like NTK, Denso I think makes the original.
| DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS | auxmike | DIY / Maintenance / Service | 50 | 12-10-2024 12:39 PM |
| Up stream o2 Oxygen sensor above 3 volts? | Yangs | DIY / Maintenance / Service | 6 | 12-16-2017 02:39 AM |
| Signal wire on Oxygen sensor??? | d.one | DIY / Maintenance / Service | 8 | 04-25-2013 12:28 PM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
