![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
If its glazed and has deep cracks on the ribs it needs to be changed. The best belts I found for this car are the OEM. You dont have to buy it from toyota. Bando makes the OEM and its alot cheaper.You can find it on rockauto and amazon. There are two sizes, one for ac, and one without. Its very easy to change. There is a 12mm bolt, and 14mm on the bottom. Since there is no tensioner, you have to get a pry bar to tighten it while putting tension on it. Pretty easy job.
You can look up which belt your cars uses on bando belts website. |
#2 | |
http://www.rockauto.com/en/catalog/t...rive,belt,8900
| Tags |
| alternator, belt, worn |
| Should I Change My Oil After 1300 Miles? | bronsin | DIY / Maintenance / Service | 3 | 10-28-2016 01:25 AM |
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 04:25 PM |
| Oil Change Question... | jayeh | DIY / Maintenance / Service | 4 | 03-05-2012 11:15 PM |
| Help with oil change | trevor1980 | DIY / Maintenance / Service | 3 | 02-05-2012 10:46 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
