Old 11-18-2017, 05:30 PM   #1
07GOKRT
Drives: 07 yaris
06YarisRS,
Did rpm make light flicker more or less? Or did you light flicker random?
07GOKRT is offline   Reply With Quote
Old 11-18-2017, 10:00 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by 07GOKRT View Post
06YarisRS,
No, it flickered from startup and RPM had no effect. It would just blink on and off rapidly but not necessarily uniformly.
Your reman alternator sounds like a Nippon/Denso, which I think is the OEM alternator. I believe there is a vast range in quality of remanufacturers. I always ask which parts they replace. Usually it's bearings, brushes and voltage regulator but that may not always be the case.
Battery/Gear Light Flickering & Alternator Not Charging AzianCuz DIY / Maintenance / Service 0 04-17-2017 06:29 PM
Battery charge light on intemittant vinny121 DIY / Maintenance / Service 18 08-24-2015 12:20 PM
Battery Warning Light - Different Twist maybe RutherfordmanX DIY / Maintenance / Service 3 06-08-2015 08:59 PM
battery light on and off yariseggvvti DIY / Maintenance / Service 43 05-04-2014 11:18 AM
Battery warning light stays on... routerunner DIY / Maintenance / Service 2 02-23-2013 09:53 AM
