#1 |
conundrum562
Drives: Toyota Yaris 2007 S Join Date: Jun 2010
01. Power Relay was stuck. Basically when I turn the ignition to off, the car would still think it's on ACC or Accessory mode, since it was stuck.
02. The whole fuse junction box, below the driver steering wheel had to be replaced. I got a used one for $290 dealership would have been $500-$700. 03. After this was replaced, I noticed that my battery indicator was flickering crazy and my gear light on the cluster was doing the same thing. Finally my alternator gave out. 04. Found out it was from a green wire that was in the fuse junction box. That mechanic probably "Cut It" for reasons unknown... Maybe wanted to make more money off of me, who knows. Not here to judge. 05. My other friend mechanic clamped the wire back together and now there's no more intermittent flickering and the alternator is now charging the battery. [IMG] [/IMG]
--------------------------------------------------------------- BLITZ SC | CERAMIC 6301 BEARINGS | MICRO-IMAGE CRANK | NST PULLEYS TRD 71C THERMOSTAT | 1ZZ INJECTORS | TB SPACER | BLITZ SRI NGK PLUGS, COILS & MAF | DC HEADERS | CUSTOM 2.25" EXHAUST GTSPEC STRUT BAR, MID & 4-PT LOWER BRACES TANABE FRONT & WHITELINE REAR SWAY BARS W/ POLY BUSHINGS TBW SKID PLATE | FULLRIVER AGM BATTERY | MOBIL 1 EP + PROLUBE
| Tags |
| alternator, battery, battery indicator, battery light, flickering |
| DIY yaris III fog lights installation | karloslatynos | Third Gen Yaris General Discussion | 54 | 04-24-2026 08:40 PM |
| yaris 2009 charging light problem | ASEMX1 | DIY / Maintenance / Service | 1 | 02-13-2015 08:33 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Charging System Light | N9QGS | DIY / Maintenance / Service | 1 | 07-26-2010 06:53 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
