Old 12-12-2017, 08:46 PM   #13
tmontague
tmontague's Avatar
Just a symptom of excess clearance in the cylinder causing the cold piston skirt to slap the cylinder wall. Once warmed up the metals get larger and it goes away.
Cars can have it for well over 5 years and drive fine. You'll just have less compression when cold and increased blow by.
If you had it had you would have a much more urgent thread and you would likely be more concerned due to the loud noise. Drive the car as you normally would and enjoy it for many years to come
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Checking oil in the Yaris jb48 General Yaris / Vitz Discussion 16 09-15-2015 04:15 PM
Oil Return on upper oil pan sub assembly BoostedTRD Forced Induction Forum 6 11-10-2014 10:23 PM
FS: ZAGE oil Pan TURBO YARIS Items for Sale by private party 1 03-07-2014 01:00 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
